Idle Problem/No power (Video Included)
  • dotheslag989
    • Apr 2012
    • 12
    anyone got any ideas? changed the oil Monday to see if that had anything to do with sluggishness, put sea foam through the vacuum lines and crank case Tuesday which helped for about a day or so, then went right back to this.
    today, had to crank it three times (died almost instantly after the first two), i let it sit for about 15 minutes to warm up, and the idle cleared up. tried to drive around for a bit, but not more than 100 ft out of my driveway, i lost all acceleration power (car was still on, but even more sluggish than in the video) and had to turn around and Fred Flinstone the thing back into my driveway.
    will try carb cleaner later tonight to check for possible vacuum leaks. but any other ideas what it might be?
    (loud metal clanking noise is because muffler and pipes separated, and missing an exhaust hanger)
  • dotheslag989
    • Apr 2012
    • 12
    throwing code 1221. changing the O2 sensor today to see if that solves the problem.
