I know I have one bad component in my system, the battery. But using an analog voltmeter I have found some other behavior that I'd love an opinion on.
First, the battery: After a good long run, and then turning the car off, I get 11.8 volts on the battery (Edit: I'm now seeing 12.3 after after 10 minutes being off). I believe a good battery should be up around 12.6-12.8? This battery is barely a year old (May of last year) and still under warranty. I'll look into getting it replaced, but before I do I want to know if anyone thinks I have a separate issue.
What do you guys think? Two separate issues, battery and an occasional miss? Or is something wrong with the system that would cause a premature battery failure and be giving the ignition system a rough time?
I might replace the voltage regulator just because I don't recall when that was done last. However my experience with a bad regulator is that the system voltage just runs high and causes gremlins. The fuel pump was tested according to the Bentley's procedure for current draw and passed. I didn't do a flow test. Cap, rotor, and spark plugs don't have more than 200 miles on them. I'd rather not replace the battery until I know it won't be immediately KIA.
Thanks guys!
Edit: I'm going to go poke at it some more. I'll update this post as I find more potential oddities.
- On starter engagement system voltage drops to 9v (battery issue).
- With the car running and at idle, system voltage is 13.8
- While at idle, putting the turn signal on causes a 0.3v drop and rise in the system with every flash.
- While at idle, pressing the brake pedal causes a momentary 0.3v drop in the system.
- Once the car is warm (or after it's run for a while), and while it's at idle, the car will see a drop in voltage of almost 0.8v every 4-8 seconds, which correlates with no external input. Simultaneous with the drop in voltage is engine roughness (sounds like missing) and a change in tone of the fuel pump. It will recover after a half second, and the engine doesn't lose more than maybe 25rpm from a steady 600rpm (a needles width).
- If I bump the RPM up to 1500 and hold it there, I get steady missing once every couple seconds. This however does not seem to correlate with a change in voltage.
- Reving the engine up to 2500rpm does not cause the voltage to go up. In fact it consistently drops from 13.84 to 13.77. I thought above 1500 the voltage would rise?
Thanks guys!
