I have an '88 (built May, '88 ) 325is. 187k miles. Been sitting in storage for 6 months and finally got it out about a week ago. I knew it would need some fuel work as there was gas smells when I put it away.
I replaced almost all the fuel line and clamps, noticed a leaking injector and have had the injectors rebuilt by a reputable place in Denver. No more fuel leaks!
Changed the oil, new NGK plugs, new air filter, adjusted valves, etc. It runs pretty good. Some odd noises from all over (suspension, maybe some engine accessories, but otherwise runs good).
The issue: occasional hard start.
I know this has been discussed, and I have read threads, but wanted to get feedback on my situation. I will assume the pump is good, the filter is pretty new, but was not replaced, and the fuel pressure regulator I believe is original (says manufactured in W. Germany!). I want to say its the fuel pressure regulator leaking pressure off the rail causing the hard start. Seem reasonable? What other symptoms would a bad FPR cause, or what else can cause hard starting?
The old bosch plugs came out consistent across all 6 (yay!) but were a bit reddish? I can put up pics of sparks tomorrow if those would be helpful. How to tell rich vs. lean and which would a bad FPR cause?
Thanks for any help! :D
