M20 No Start, Cranks All Day
  • eskimo810
    • Nov 2011
    • 295
    Hey guys,
    I finished getting my car together. Swapped in a Myster-E head w/ 274 cam, 19lb injectors, and the appropriate Mark D chip. On the first try it started up briefly with the help of some added throttle, however every subsequent try there was no ignition. I tried it a few times.
    Thanks for any help!
    Edit:
    Video of first crank: http://www.youtube.com/watch?v=hNLqc...ature=youtu.be
  • dougie30
    • Apr 2012
    • 1708
    Check your cps. After that check your cps again, and right after that make sure to check your cps
    M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
    • eskimo810
      • Nov 2011
      • 295
      Alright so I've gotten around to trying some things.
      -I swapped in my old 153 ECU with no chip and it acted exactly as it has been. I put the new 173 back in.
      -I can hear the fuel pump click when I turn the key to the "on" position.
      -I started going through the troubleshooting guide that jlevie posts often: http://www.r3vlimited.com/board/show...CPS+resistance
      Resistance across DME pins 47 & 48 is higher than it should be at around 670 ohm (+/- 15, analog meters FTL.) I get the same reading when I test the pins on the connector near the front of the engine. Is this the sign of a failed CPS? Or would there be no resistance if it was failed?
        That sounds like a bad CPS if your meter is reading correctly.
        • e30trooper
          • 11576
          Change the cps , check the main relay or fuel pump relay. Try doing a stomp test? Did you get the cps and that spark plug wire adapter mixed up? They look the same.
          • ak-
            • 12422
            I want you to not listen to anyone and just check your CPS
            1991 325iS turbo
            • eskimo810
              • Nov 2011
              • 295
              Update: Bought a new CPS and got it this morning. Still no start, in fact, the only change is that my multimeter is now showing the resistance as a touch over 500ohm. I'll keep investigating today, welcome to any suggestions! Thanks for the help so far.
                When cranking is there spark, correct rail pressure, and injector firing?
                • SmokeE30
                  • 1730
                  So the fuel pump is for sure not turning on? If the cps is good and the relay is good you should have power to the pump. Test for power at the pump while cranking, it must be cranking not just key on. If no power is present look at the relays
                  Shawn @ Bimmerbuddies
                  Bimmerbuddies LLC
                  717-388-1256
                  2971a Roundtop Rd, Middletown PA 17057
                  bimmerbuddiesllc@gmail.com
                  • e34_spangler
                    • Dec 2012
                    • 311
                    If you smack your fuel pump will trying to start the car and it starts you have found your problem its a fuel pump that's an easy check
                    • eskimo810
                      • Nov 2011
                      • 295
                      I should have said this earlier, but the fuel pump is good. Sends a nice healthy flow of fuel out of the line leading to the fuel rail. A good blue spark is also present.
                      • eskimo810
                        • Nov 2011
                        • 295
                        I don't have a way to test fuel pressure at the moment unfortunately. How would I test if the injectors are firing? That's what I feel like the problem is, and I was hoping the CPS would rectify that. I did check the "screw-type" connection for the injectors coming from the wiring harness, but that was all.
                        • mzollo
                          • May 2012
                          • 120
                          **EDIT** i see you checked it, but make sure its not coroded etc
                          please check plug C191 it is underneath the intake boot and throttle body it is a round 7 pin plug that controls your injector harness. notorious for corrosion and holding water. i had a similar issue
                          • eskimo810
                            • Nov 2011
                            • 295
                            I did check to make sure that it was actually connected, but I'll separate it and examine any corrosion.
                            Edit: Checked that plug, doesn't seem out of the ordinary. In your experience was the evidence of corrosion fairly obvious? Mine is a little dirty but doesn't seem bad. I don't think it was ever exposed to rain or anything.
                            • mzollo
                              • May 2012
                              • 120
                              well, the main issue with that plug is that the rubber boots hold back water and sometimes coolant which leaks from the throttle body, granted my coolant lines to the TB were deleted but my boots still had loads of coolant(OLD) and water. so i had to delete the plug all together.yes my corrosion was green and looked like an old battery terminal
