L-jet 323i - low power, fuel rail loses pressure in 5 minutes
  • frankenbeemer
    • Sep 2009
    • 2260
    Seems like a very good price on the wideband. I'll try to search out that book.
    Don't buy an e30
    They're stupid
    1989 325is Raged on then sold.
    1988 325 SETA 2DR Beaten to death, then parted.
    1988 325 SETA 4DR Parted.
    1990 325i Cabrio Daily'd, then stored 2 yrs ago.
    • kronus
      • Apr 2008
      • 13032
      let me know if you find it. I am curious about what #1 Partial Throttle Switch does - there is a similar-looking sensor on Motronic engines, but it is a barometric pressure sensor and doesn't have a vac line running to it.
      cars beep boop
      • bloodsnot
        • Jan 2013
        • 60
        Do you have the "2/3 way valve" (#8 in the diagram) on your car? I can't find that on mine..
        '75 Honda CB400f
        '85 BMW 323i Euro
        '04 Acura TSX A-Spec
        • kronus
          • Apr 2008
          • 13032
          I don't think I have #8 or #14. I'll take some photos when I'm down there tonight
          cars beep boop
          • bloodsnot
            • Jan 2013
            • 60
            That would be much appreciated!
            '75 Honda CB400f
            '85 BMW 323i Euro
            • kronus
              • Apr 2008
              • 13032
              well, it's not the timing belt being off, both marks are right on the dot.
              I'm putting together a ghetto smoke tester and checking the distributor advance/retard lines.
              cars beep boop
              • kronus
                • Apr 2008
                • 13032
                So I built a smoke tester out of two vw hubcaps, some hose, an air sprayer, a zip tie and a rag:
                you have to keep the air intake closed:
                using that, I found that the distributor retard line was completely severed at the distributor. fixed, but didn't solve vacuum issue.
                then, I read a lot about timing m20 engines with distributors and figured out that I did it drastically wrong the first time - I'd set it to sit at the O|T mark at 3k RPM, because I mistook it for the 19 deg advance line (Z mark), since both had convenient yellow lines drawn over them, and the distributor was maxing out its travel before getting to the correct advance setting.
                I pulled the distributor out, advanced the rotor manually to give it enough travel, reset the timing to the correct 19 degree BTDC at 3k RPM, verified no more vacuum leaks, and went out for a test drive. Power felt better than before, but not great, and now it is backfiring a lot on power, idles at ~1200 and smells fairly rich. Ideas? Could this be just because I have the exhaust off pre-cat?
                edit: did some reading. Backfiring could be due to running overly rich OR overly lean. It also could be due to too much advance, OR not enough advance. lol.
                I'm going to see if putting the exhaust on will make the backfiring go away, and also check AFRs, although I'm not sure what can be done to fix AFR problems on an L-Jet engine.
                Annoyingly, the idle vacuum has only slightly increased, from 5 in hg to 8 in hg. Running out of ideas, although the high idle continues to point to a vacuum leak despite the smoke test's inability to locate any after I fixed the distributor line.
                cars beep boop
                • bloodsnot
                  • Jan 2013
                  • 60
                  Did you try a different fuel pressure regulator?
                  Have you had your injectors ultrasonically cleaned and flow/leak tested?
                  Check for leaks around your manifold gaskets..?
                  '75 Honda CB400f
                  '85 BMW 323i Euro
                  • kronus
                    • Apr 2008
                    • 13032
                    the FPR is new, I've verified that the rail pressure is good when the car's running.
                    I haven't done the injectors yet, since I can't find a place that rebuilds low-impedance l-jet injectors.
                    smoke test showed no intake manifold leaks.
                    cars beep boop
                    • bloodsnot
                      • Jan 2013
                      • 60
                      Did not know L-Jet has special injectors. Do you know why/how the impedance would matter when cleaning and testing them?
                      '75 Honda CB400f
                      '85 BMW 323i Euro
                      • kronus
                        • Apr 2008
                        • 13032
                        they're a different generation of injectors... I don't think many people stock the rebuild parts for them anymore. Everyone uses the modern, universal Bosch style, which is why you can fit Ford 5.0 injectors to an M20.
                        cars beep boop
                        • bloodsnot
                          • Jan 2013
                          • 60
                          Okay. But the only parts they'd use would be the pintle caps and O-rings, right?
                          My car is an '85, perhaps it has the newer generation of injectors? I mean, they came back with new pintle caps that were identical to the ones I sent them off with when I had them cleaned/tested.
                          RealOEM gives me 13641284408 as the injector part number. I'd have to go pull the fuel rail to see if that's what's in there...
                          What p/n are your injectors?
                          It's possible that the previous owner swapped in some newer ones on my car, of the universal Bosch type, and this could be why they could be serviced. I don't know if they're a drop in replacement, though, or if they'd cause any issues for the L-Jet controller..
                          '75 Honda CB400f
                          '85 BMW 323i Euro
                          • kronus
                            • Apr 2008
                            • 13032
                            from various rumors on the internet running the wrong injectors is "bad". I don't know what the actual effect is...
                            to my knowledge L-Jet always uses low-impedance injectors.
                            what place did you use to get yours serviced?
                            I'll check my injector PNs tomorrow night.
                            cars beep boop
                            • bloodsnot
                              • Jan 2013
                              • 60
                              Yeah, that's the general impression the internet has left with me over the years, too. I have this vague recollection of the previous owner talking about putting in higher flow injectors that gives me night terrors from time to time. I'll be pulling them out to take a look once my roommate's M-B diesel gets out of the driveway later this week; it's been bothering me for a while and this is a good excuse to take a look.
                              Would these low-impedence guys be available in the same form factor of a universal Bosch injector? "Low-impedance" would indicate to me a different signal requirement to operate at the very least but nothing about the fitment to the manifold or fuel rail.
                              I went to Dr. Injector (North). It was essentially a drop box in some dude's driveway that had envelopes and markers in there for you to drop off your injectors after paying over the phone with a card. He called a day later and I picked them up in the same box with a flow/leak test report and some candy. This cured a hard-starting-when-warm issue I had been having at the time (that has since reappeared).
                              Just navigating to your year/make/model on RealOEM, it would seem that you have injector part number 13641284408, different from what mine came from the factory with. Without knowing your VIN number I can't guarantee that to be 100% accurate. Would be curious to know what they actually look like if you could post pictures...
                              '75 Honda CB400f
                              '85 BMW 323i Euro
                              • kronus
                                • Apr 2008
                                • 13032
                                the injectors in my 323 are PN 0280150208:
                                oddly, this table says they're high-impedance.
                                cars beep boop
