bad fuel pump??????
  • custom e30
    • Nov 2009
    • 347
    bad fuel pump??????
    my set up
    1988 325i Turbo
    holset hx35w
    36lb injectors
    15psi
    fmu
    tre performance 255lph pump
    issue - when cold start, the car starts and runs just fine, after about 10 miles of driver ill notice my wide band getting leaner at idle, car starts to have rough idle,
    ive replaced fuel pump bracket, all new wiring, checked the intire fuel system for leaks...
    today it did the same thing again???? HELP!!!!
  • custom e30
    • Nov 2009
    • 347
    im guessing my pump could be going bad, but i went ahead and ordered a new fuel pump relay and fuel filter for fun, any help, thanks
    • Earendil
      • 1662
      If you want to eliminate the pump, buy a fuel line pressure gauge, and stick it near the rail on the line going into the fuel rail. If the pressure is good, and doesn't drop under load, your pump and filter aren't the problem.
      If the pressure is bad at idle, but doesn't drop under load, it's probably your FPR.
      1989 - E30 - M20B25 - Manual. Approx 300,000+ miles - Track Rat & Weekend Fun
      2000 - E46 - M52TUB28 - Manual. Approx 130,000 miles - [not so] Daily Driver
      I'm looking for a Lachssilber Passenger Fender and Hood. PM if you have one or both to sell!
      • custom e30
        • Nov 2009
        • 347
        im gonna do it right now
        • SmokeE30
          • 1730
          You need to t a fuel pressure gauge into the car to see what is happening when your AFR leans out. Without doing that you can't know for sure if it's even a fuel issue. It could be vacuum leak problem. Things heat up and expand making gaps larger allowing more air in once warmed up. Check fuel pressure and check for vacuum leaks then report back
          Shawn @ Bimmerbuddies
          Bimmerbuddies LLC
          717-388-1256
          2971a Roundtop Rd, Middletown PA 17057
          bimmerbuddiesllc@gmail.com
            • 37834
            Checking fuel pressure is a good start for sure. You don't really need anything bigger than a stock pump even with a boosted engine. What you need is the right engine management and tuning, not a bandaid system with a FMU. Trust me, been there done that.
            Grover Beach, California
            BimmerHeads.com
