So im still battling with coolant leaks on my car. A little bit of background. Its an 86 325es I bought from a dude that said it had "A hose leak" so I snapped it up for $800 bones.
I test drive the thing up and down the road and it seems ok, the temp gauge never budges(I though was weird but chocked it up to the sensor or a jaked SI board).
I get it home and top of the coolant to try and find the leak and it starts gushing out of the block. The "Hose Leak" turns out to be a missing freeze plug, 2nd one from the back on the pass side. So I punch a new one in.
Top it off and no leaks until I run the car for a min. POP another freeze plug goes, same one but on the drivers site RIGHT behind the starter
I managed to get one in, top it off and no leaks until I start it again.
Now I have a slow-leak that looks like its around the back of the head somewhere and the temp gauge still isnt budging (I replaced the batteries and cleaned all connections on the SI board and tested with a multimeter so I dont think thats the problem). I thinking maybe headgasket?
I have a headgasket and timing belt kit on its way in from Pelican so Ill likely do that anyway, at 160k it probably needs it.
Has anyone had this much trouble with the cooling system or something similar? HALP!
.I managed to get one in, top it off and no leaks until I start it again.
