So the motor is a m20b25. sometime in the past 10k (before purchase) it had the head replaced due to a tb failure.
Now on to the issue, Under normal driving conditions it recently has begun to run a little hotter. (It was running cold when I first bought it due to a thermostat stuck open, replaced that last fall with a lower temp tstat. after that the temp would never rise above 1/4, functioned perfectly.)
Now after I pulled it out of storage this winter it started running a little hotter from time to time (especially when I would pull off the highway). It would sometimes climb to the one third mark. I chalked this up to a fan clutch so bought that (havent installed) but I've also noticed I've topped off the coolant more than I'm comfortable with. It never empties the reservoir but every couple of weeks it will get low enough to trip the light.
No visible leaks, never even comes close to overheating.
So I tested the head with a block tester (sucks air in from the overflow tank through a fluid to test for presence of exhaust gases) which came up negative. Is it possible because of the slow rate of coolant loss that the exhaust gases are only entering coolant under certain conditions?
So basically to round it up, heres the issue
car runs hotter than I would think it should, creeps above 1/4 sometimes to 1/3, especially when coming off the highway. Also Ive noticed that if I warm the car up, turn it off, and back on the temp is high, it will come back down to just above 1/4, but is it possible this is when I'm loosing coolant out the overflow hose (ive noticed its a little damp at the end once or twice). I'm a little stumped here.
Theoretically new
water pump
h/g
on the newer side
thermostat
radiator
Theoretically new
water pump
h/g
on the newer side
thermostat
radiator
