I have a 1988 325iC (5MT).
I've been having a strange problem with my e30 for a little while.
I've researched on what it could be based on the symptoms, but am unsure which tests/ cleanings/ replacements to perform first.
Here are the symptoms:
- CEL is on (will do stomp test for code)
- the car drives great until it warms up. once it warms up and roughly 10 minutes after driving it feels like the car is losing power, the throttle is unresponsive and the rpm's stutter (bounce around) from 500 to 1500. this happens both when the car is standing still (clutch engaged), or placed into neutral.
- once this happens, if I turn off the car for about 15min and drive again, the problems will not reappear immediately, but will appear roughly 5-10 minutes after.
- if I try to turn on the car immediately after turning it off, the car does not turn over unless I pump the gas pedal.
- also not sure if this is related: the throttle cable has a little big of slack. (will tighten or replace)
Based on reading some forum posts:
- need to check for a vacuum leak?
- need to clean the ICV?
- check if the fuel pump is working?
- check if the fuel relay is working?
If you've had an experience with this, or have had a similar problem, let me know what steps you took to fix it.
Any help would be appreciated.
Thanks!
Thanks!
