front passenger side oil leak
  • dougie30
    • Apr 2012
    • 1708
    I just got my car running and i found out it has a oil leak pretty much on the front passenger side of the engine block above the oil pan.
    the weird part is that i have no exhaust yet so i havent ran it in over 2 weeks or so and i cant figure out where its coming from. i changed the valve cover gasket, valve cover rubber plug things, head gasket, oil pan gasket and water pump gasket. pretty much every thing except my cam seal and the gasket on the front near the crank.
    I dont think its the cam seal or crank case casket because its on the side of the block in front of the oil filter so im not sure where it could be coming from.
    any idea would be awesome and it almost looks like its coming from the head gasket but i highly doubt that because im sure i did everything correctly with that.
    M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
  • dnguyen1963
    • Nov 2011
    • 2651
    Have you checked the oil sensor? The gasket gets old and can leak a lot of oil.
    • 603Racing
      • Dec 2010
      • 612
      ^ This.
      90 325i DD/Track
      03 Durango 5.9
      Originally posted by e30mpg
      It is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.
      • dougie30
        • Apr 2012
        • 1708
        Haven't even thought of that... Will do
