Can I thermostat cause the engine to run really cold and push coolant out the overflow?
thermostat symptoms?
Tags: None
A bad thermostat that is stuck open will cause the engine to run cold. But fluid being pushed out of the overflow will be from a head gasket leak that is pumping air into the system and causing the cap to lift to vent the excess pressure or a bad cap.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, AL -
So your saying a head gasket and cap are only causes of coolant coming oiy the overflowComment
