89 e34 m20b25
My mom called me up saying she heard a clunk and thought she ran over something, then seconds later the car died and she coasted into a parking lot. Not really sure what the clunk was, but found the negative terminal split in two so I replaced it.
However, she tried starting the car afterwards (after it died). It sounded like it was just the starter spinning and not poking out. I hit it a few times, no cigar, so figured I had a worn armature and needed a starter. I called a friend and he said "if the starter is spinning normally but not engaging, its probably got proper continuity and not a wiring issue".
Now for the bs. I fumbled my way with removing the starter using a rediculious setup (had 16mm nuts on it? and could not find a 16mm wrench). Finally removed the starter, and tested on the ground. The bastard spun and poked out. I decided that since it did that, the starter was good and to plug it into the harness. With it wired up but not bolted into the trans, I cranked it and it operated as normal! I bolted her into the trans, and she just spins but doesnt mate the flywheel!
The flywheel teeth seem fine to me. Teeth on the starter are ok. I have 12v at the big terminal hot. The 8mm terminal and 10mm terminal do not have 12v koeo. The 8mm greenblack wire ohm tested to have continuity from starter to the pcm. The black yellow wire I have no clue.
I couldn't find a wiring diagram that had all 3 wires in it to trace them back to make sure they arent open. I think its a circuit issue between the 8mm or 10mm wire not getting power, so the armature cannot get powered to poke out.
Any ideas? Any actual wiring diagrams? Wedophone diagram only shows one wire.
Appreciate the input after a lengthy post, just trying to get my moms e34 back on the road.
