hey everybody, got a 1986 325es 2.7 inline 6
1)How exactly do I check if the fuel pump is working if I removed it? what if it is still attached underneath the car?
2)How to check fuel pressure regulator?
'86 325es seems to only start intermittently. Car cranks but won't start. However, every now and then it seems to start. and it looks like it starts after the car has gotten some rest after cranking it a bunch of times.
Today I've check the fuel pump relay by jumping pin#80 and 37 to see if I can hear the fuel pump working but didn't hear anything. Right after I plugged the relay back in and then start the car and it works! For about 3-5 seconds of run time. Also checked the wiring to the in tank transfer pump with a multimeter and that seems fine. I also checked the wiring to the external fuel pump(near rear driver's wheel) and it reads 12v.
How do I know my main fuel pump is actually out? It seems like if I give the car a good amount of rest time inbetween tries to start the car, it will work. But if I try to start the car again it won't start.
Possible that the main fuel pump has overheated and will only work with rest?
I want to order a new main fuel pump, but the fact that the car starts after some rest tells me it might be something else..
Thanks!
Thanks!
