Car idling funny after oilchange
    All i did was change the plugs(ngk to bosch) change the oil and flush the collant and the car is acting like its rellearning to idle(has 19lbd injecter and markd chip) idle is erratic and when it does calm down is high @~900-1100 rpm, beofre it was steady at 750 any ideas?
    Put the cap on the valve cover?
      Brilliant! what do I owe you? :-)
        Check the gap on the plugs you switched out to make sure they are in spec
        1991 325iS turbo
          i took the caps of the plugs but i dont think that would do it, gap was all in spec
            is it possible over time the vicosity breakdown of the oil taught the ecu to have x pulse width and w the higher viscosity of the fesh oil it is now idling high? maybe i should reset the ecu?
              This, happen to me before. Thank god I caught it before I drove off or else engine bay would be a mess.
                E30s aren't that smart. I would bet you accidentally knocked something and something came unplugged.
                  i kinda thought that too
                    Danny has a big brain went to check the code no code=TPS unplugged not sure how that happened but thank
