quick question about coolant flush
  • bastianshaw
    • Jan 2007
    • 2210
    Im flushing the coolant and it came out straight rust, im just undoing the radiator drain, draining, then filling it up with water(after it cools) do I HAVE to drain the block?
    Wont the water pump "flush" the block and I can drain it out the radiator drain?
    Im about to do the TB and want to get all this shit out before i replace the cooling stuff
  • LateFan
    • May 2013
    • 4414
    The block drain is easy - it's behind the rear exhaust manifold, big hex plug. Quite a bit of water comes out of the block when you pull this. I did both block and radiator last night in different combinations of open / closed / hoses off, in order to wash it around and out.
    It's worth it if yours looks crappy.
    • s14pwd
      • Apr 2012
      • 116
      Ya it will mix and dilute, but it would take more flushes your way to achieve the same effect as draining the rad and the block. When I first got my car I drained the Rad and the Block 5 times I think, filling with distilled water each time, running for 10min in between. Basically until the drained coolant looked like water.
      • bastianshaw
        • Jan 2007
        • 2210
        Yea this is what I'm going for, I'm also using vinegar. Not sure if that helps or not, I cannot believe the amount if rust.
        So 5 flushes and it was clear?
        • golde30
          • 11464
          damn, 5 flushes seems like alot. also you wasted that distilled water, just use tap water for flushing and distilled at the end when you refill the coolant.
          This is why you run the real bmw coolant and distilled water in bmw engines. i let my s50 sit for 4 years, when i drained it out it looked brand new. The problem is people like to keep topping off their cooling system with tap water, and over the course of a few years that tap water rusts the shit outa the internals. I saw this ALL THE TIME when i was a mechanic.
          IG: @Baye30
            Here you go...
            1) Get the front of the car 1-2' in the air on jack-stands.
            2) Drain the coolant, remove the thermostat, and set the heater controls for
            full hot. O-ring sealed thermostats require you to make up a temporary
            gasket, which can be made out of pasteboard.
            3) Add flush compound and fill with plain water. Then run the engine at normal
            temperature as specified by the flush manufacturer (usually about 15
            minutes at operating temperature). In cooler weather it may be necessary to
            block off some of the air into the radiator to decrease the warmup time.
            4) Allow the engine to cool until you can place your hand on the cylinder head
            w/o discomfort. Drain the system and refill with plain water.
            5) Run the engine for 10-15 minutes or until temp is close to normal.
            6) Repeat (4) and (5) until the water drained from the system is clear and
            free of debris.
            7) Fill with coolant. It is best to dilute aiitfreeze with distilled water.
            Tap water contains disolved oxygen and may contain minerals. Either of
            which will reduce the lifetime of the coolant.
            Notes:
            You don't absolutely need to remove the thermostat, but doing so will allow
            continuous flow through the radiator and will also make draining & filling
            faster and easier.
            Always allow the engine to cool to the point that you can hold your hand on
            the cylinder head without discomfort. That will prevent scalds from hot
            coolant and prevent thermally shocking the head when you dump the coolant.
            Filling the system with hot water makes the process go faster and keeps from
            having to run the engine a lot in a cold condition (rich mixture).
            A few ounces of Cascade dishwashing detergent is a reasonable substitute for a
            commercial flush compund.
            A rusty cooling system needs an oxalic acid flush. Kits for that (containing
            oxalic acid and soda for neutralizing the acid) used to be available, but
            arent now. Citric acid also works, but not as well on rust as oxalic acid. 6oz
            of oxalic acid and 4oz of soda will treat a 1-1/2 to 2-1/2 gallon cooling
            system. The procedure is like the above with an extra step 4 where the soda is
            added before the series of fill/drains are done. An engine that needs this
            treatment probably has a pretty severly clogged/damaged radiator and heater
            core, which stronly suggests that they be replaced after usin this procdure on
            the cooling system. A cooling system that needs this treatment should have a
            detergent flush, the acid flush, then another detergent flush. The initial
            detergent flush will clean out any oil, which would interfer with the acid
            flush, and the final detergent flush helps to wash out loosened sediment.
            • IRON-E
              • 16548
              Originally posted by jlevie
              Here you go...
              free of debris.
              Notes:
              faster and easier.
              Holy Jeez, this man deserves an honorary medal or something, he is on point every time I read his replys.
              I will save this for future referance.
              @IRON-E30 aka Edwin:D
              • bastianshaw
                • Jan 2007
                • 2210
                is it weird that im not getting coolant out of the bleeder screw?
                  The passage in the tstat housing could be plugged.
                  • Eddie Haskell
                    • 102
                    Oxalic Acid is avaliable at most good paint stores or HD. It's used for bleaching wood. A good Neutralizer is common Baking Soda. If your flushing a radiator with Oaclic Acid flush with tap water . Plug the radiator and pour in a half box (small box) of Bakeing Soda then pour in a Large Bottle of Coke and shake. Flush the mixture and you will be good to go.
