Ok so I just got back my e30 from the body shop this past thursday it took a little to get it to turn over but it did and ran fine, this is after sitting for 7 months never being turned on. Well saturday I didnt drive it nor did i turn it on but I thought I had nothing to worry about because both thursday and friday it turned on just fine, ran alittle ruff but fine, I mean after 7 months it I could see it running alittle ruff right? By ruff I mean when I would step on the gas pedal it would loss power after 3k and slowly work its way up to 7k in any gear, but with in 15 20 minutes it was fine.
Back to the point well yesterday, sunday, I went to go turn her on and drive it well she wouldnt turn on at all starter was working fuel pump and injectors were working but I wasn't getting and spark. So my father and I decied the best thing to do was to pull start it :down: which I was tottaly agasint because the car was fresh out of the paint both. Anyways after many attemps it finaly turned over and ran. So some how we got spark again? and after about 15 20 minutes she was as good as new? we even shut her off a few times and let her rest for 30 minutes to see if she'd do it again and surly enough she started right up?
Now this morning the same thing happened
she wouldnt turn over at all then all of a suddent she turned on ran really crapy then sputtered out with in seconds. so I gave her a minute and tryed again she kept cranking but nothing she wanted to turn over twice and nothing then all of a suddened she started right up. Same probelms as before after about 3k hardly any power but would make it to 7k.
things changed
spark plug wires - got off runnng car looked new
cap and rotor - got off running car looked new
coil - brand new
ecu - got off same running car
cps - brand new through dealer
cliff notes
car starts up after 7 months and runs ok for 2 days considering
didnt drive it one day have to pull start it the next to get it to turn on
no spark when cold
backfires when trying to start and smells like pure gas out of the exhaust when trying to start
takes 15 20 mins to warm up then runs fine
she wouldnt turn over at all then all of a suddent she turned on ran really crapy then sputtered out with in seconds. so I gave her a minute and tryed again she kept cranking but nothing she wanted to turn over twice and nothing then all of a suddened she started right up. Same probelms as before after about 3k hardly any power but would make it to 7k. things changed
coil - brand new
cliff notes
no spark when cold
