M20 wont stay warm
  • Cephas
    • Apr 2012
    • 878
    M20 wont stay warm
    I just replaced the thermostat with a new 80c unit and the problem still exists. The car will warm to 1/2 no problem when idling, but once I start moving it drops to just over 1/4.
    Could the clutch fan be sticking?
  • ak-
    • 12422
    I wish I had your issue.
    Anyways, that's pretty normal. Fan spins faster as the RPM's go up.
    1991 325iS turbo
    • Cephas
      • Apr 2012
      • 878
      Hehe. Yeah I know. But the car runs too rich in closed loop and stinks.
      • mod_junkie
        • Jul 2012
        • 285
        thats pretty normal mine stays at 1/4 when moving and I believe everyones does that LOL at least all the e30s ive seen.
        Originally posted by Rocla
        And yes, you must remove complete assembly from the car, unless you are a gynegologist
        • Cephas
          • Apr 2012
          • 878
          Well the other 2 e30's that I have had direct experience with both warm up to just under 1/2 and stay there.
          The exhaust smells very different at 1/2 than at 1/4....maybe it's all in my head, but I don't think so. It could also be that the car doesnt have a cat converter.
            The needle being between the 1/4 & 1/2 marks is normal. As a sanity check, measure the temperature of the head and thermostat housing with a contact or IR thermometer.
            • Tyler325i
              • Jul 2011
              • 64
              If you want it warmer you could always get a warmer thermostat, I went with a colder one because I didn't want it to run so hot
              Stroked out and poked out
