crank bearing cap bolt size
  • dwight
    • Dec 2012
    • 550
    Any one have an idea what size bolts hold the crank bearing cap on a m20b25 motor.
    Thanks for your help
    D
  • Kozworth
    • May 2011
    • 1339
    If your talking about the main bearing caps.. I believe its a 17mm but I might not remember. If you mean rod end caps.. you need torx bits.
      Main bearing bolts can be reused, but rod bearing bolts must be changed each time. In this case I go to my dealer for the bolts.
      • dwight
        • Dec 2012
        • 550
        Thanks for your help everyone
        D
