Sudden No Start: No Fuel/Spark
    88' 325 M20/ Manual 178k miles
    So on my way in to work this morning I feel 4 intermittent distinct jerks while driving a sustained 70 mph. I thought to my self that my fuel pump was on its way out. I arrive at work and shut off the car. I return 12 hours later to go home and nothing. I immediately check the fuse and jump the relay. I hear no noise or feel no movement from fuel pump. I disconnect fuel line and there is no fuel pressure. I cranked the engine and no fuel was delivered. I then shot some carb cleaner to see if the engine would fire...nothing. I then removed and checked spark on 2 separate plugs....nothing. So I have no spark OR fuel.
    I'm thinking bad CPS. I'm going to ohm test it tomorrow. Any other way to test/bypass it? Anything else I should check?
    . Any help would be appreciated. I'm going to have it towed 100 miles on Wednesday and would like to avoid that if possible. Thank you!
    CPS or main relay would be the first suspects and the best diagnostic is replacement.
