Disregard, I found a previous thread.
I've been around e30's for a while, but I'm new to eta's and the old 2.7 setup. I've looked on realoem.com and found the three different temp sensors my '84 eta has. I suspect one of them may be starting to fail and since they are appear to be original I want to replace the one or two that affect the motor/ecu. The temp gauge works, so I don't need to replace that one.
My question, which sensor performs which function? I've addressed this same issue on my 325i, but that was pretty easy to determine. The three for my eta are:
ENGINE COOLANT TEMP SENSOR 2110788115
Temperature sensor, water 13621357414
TEMPERATURE-TIME SWITCH 13621274630
