Alright guys, 87 325. 2.7. I am 100% stumped as of right now.
The other day I was on my way home from a buddies house when I noticed the car was puttering a little bit, threw up a red flag and wanted to get it home.
Bam, I was turning out of his neighborhood onto a road and it died... and would crank and start but die immediately, then if i gave it gas it would run for about a second longer then die again.
Had it towed back to my buddies house where we looked into it more, lot of people said CPS, I couldn't even find mine, I did find this pic and I have no such plug
We tried a bunch of stuff to get it running. Looked at the intake boot, perfect, then we unplugged the coolant temp sensor and it would fire and idle, but very badly at like 400 rpm, then when we would plug the connectors back in it would die again. we then tried pulling fuses 10 and 11 to the FI system, plug one back in and it still didn't start, switch that around and again it idled, badly. Plug the other fuse back in and back to a normal idle for a bit then it'd die again after a few seconds. Starting to get perplexed honestly. Then we take an automotive stethoscope and put it on the fuel pump, was kicking on fine and sounded fine, also I noted that I didn't see another pump anywhere else? I looked near the fuel filter(Which is also brand new) and didn't see anything.
Go to my work (Oreillys) and happen to catch one of my good mechanic buddies there and he tells me to replace the fuel pump relay, I did and it did nothing.
Get aggravated and call it quits for the night, We'll spark test it in the morning.
Next morning rolls around and we go to spark test it, fires up like a charm and idles right around 900 (Which was always normal for me), Dafuq? Drive it home and not a single problem. ran perfect....
Next day I had to go to the bank so I went to fill my tank because I needed gas, ran perfect all the way to the gas station (5 or so miles) Fill'er up and boom, no start. THE FUCK MAN. get it towed home on a buddies trailer and take my truck to work.
Next day (Tonight), drove to work fine and as a last ditch effort was a new air filter that my buddy suggested to try because mine was odd and DEFINITELY needed to be cleaned, threw a new cone filter on it and had it idling at work for about 15 minutes, I would shut it off, let it sit for a couple then go start it again and it would start right back up and idle fine. Dafuq. Drive it to my buddies house on the way home, fine and not a single hiccup, then I leave his house, again fine with no problems, get to my house and it dies in my driveway.
Guys I don't have the money to go throwing parts at it. I'd like to know if someone else has had this happen because from what I am seeing or thinking, something in the engine bay is getting heat soaked and doesn't wanna work. Now I tested spark another time in there while the car was running and it was fine across the board. My co worker told me it could be a coil? maybe but how is it running fine sometimes even at full operating temp?
I am at a total loss right now and Just want my car to be reliable again.
