Dudes, my m20 is cutting out
  • bastianshaw
    • Jan 2007
    • 2210
    arounf 4k and above at high throttle settings or full throttle I suspect either the coil or the fuel pump
    runs up fine sometimes and WILL hold 6000rpm but sometimes when accelerating quickly i get a sudden power loss, CEL, a pucker in my bum....I usually just upshift and its fine and keeps driving
    any ideas?
    im running 19lb type 3s and a markd chip for said injectors
  • rhE-30
    • 498
    Try adjusting the T.P.S. I had similar issues, and this did the trick.
    • bastianshaw
      • Jan 2007
      • 2210
      Originally posted by rhE-30
      Try adjusting the T.P.S. I had similar issues.
      Total momentary power loss?really?
      • rhE-30
        • 498
        During acceleration it used to feel like the engine was misfiring a lot and not accelerating above a certain point. I couldn't tell you that point because my tach doesn't work but it was pretty consistent during acceleration.
        • bastianshaw
          • Jan 2007
          • 2210
          ok i thought i was pretty clear this is inconsistent runs great cuts out runs great like a r3vlimiter but happens around 4-6k
          • rhE-30
            • 498
            I meant consistent at WOT, not throughout the rev range. It ran great until trying to accelerate aggressively. I adjusted the TPS so it clicks near closed throttle and clicks at WOT and my issue was fixed.
            edit: I'm no e30 pro, your issue maybe something else. Also post up some details on the ride, early or late?
            • Swanny
              • Mar 2012
              • 2834
              Brother's car is doing a very similar thing. Easy to test the TPS but I'm not sure that would cause random surges/jerking. Issue is still occurring on his car but I was able to figure out the air intake sensor was way off and could be reeking havoc on the ignition timing. He just got an AFM to test out today. If you figure anything else out let me know! Will post up an update if the new parts fixes the issue.
              Swanny!
              SUCKERS.
              • Mthrizzle
                • Oct 2007
                • 390
                check gas tank for deposits
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  Bad spot in the AFM maybe?
                  • Swanny
                    • Mar 2012
                    • 2834
                    Figure anything out?
                    Swanny!
                    SUCKERS.
                    • Exodus_2pt0
                      • 5943
                      I'd check the coil. Could be a weak spark, but strong enough to burn in a low load scenario.
                      I've had this happen multiple times, easy driving will be fine. But the coil just can't keep up with under hard acceleration.
                      No E30 Club
                      • Andy348
                        • Sep 2009
                        • 688
                        Had a similar problem (minus the CEL) at it was caused by rust/debris in the gas tank.
                        • Swanny
                          • Mar 2012
                          • 2834
                          That it was getting stuck in the feeder pump sock?
                          Swanny!
                          SUCKERS.
