M20: New Head/30# Injectors: Won't start
  • RLTW86
    • May 2013
    • 68
    'Evening Gents,
    My first e30: 1990 325is that I'm building up to put on a turbo. I'm pretty new to fuel injection so any and all constructive advice is welcome.
    Having trouble getting it to start after tearing it apart. Here is a list of the relevant things that I've done to it.
    All new engine seals top and bottom.
    Cometic .098" MLS head gasket. ARP head studs
    New water pump/thermostat/timing belt/tensioner.
    8mm plug wires
    30# high impedence injectors from VAC
    Myster-E/Bimmerheads ported and polished head with their "turbo" cam.
    New O2 sensor
    New spark plugs
    Everything else related to spark/fuel/air is stock for right now. The car was running on a knock-off Dinan chip that I replaced with a stock one.
    When I turn it over it begins to start and has a rough idle for about 4 seconds and then cuts out. When I continue to crank it, it just floods. All the plugs are getting good spark, and all the injectors are firing.
    I have a few ideas on what the issue could be, but figured I'd ask some guys that have waaay more experience with these cars than I do first.
    Thanks in advance!
    All I wanted was a tomahawk....
  • dnguyen1963
    • Nov 2011
    • 2651
    30 lb injectors? No wonder your engine is flooded with fuel. Anything above 19 lb requires proper chip and tuning for the engine to run right.
    • RLTW86
      • May 2013
      • 68
      Thanks,
      That's what I was figuring. I was just hoping that it would at least run long enough to get it over to my buddy's shop so they could tune it. Looks like I may have to throw the old ones back in first...
        • 37833
        Yeah it's not going to run those injectors on a stock computer.
        Until it's boosted I'd recommend putting some M50 injectors in there.
        Grover Beach, California
        BimmerHeads.com
