Need advice / help.. Lots of it.
  • e30kings
    • Oct 2013
    • 35
    I recently picked up a white 86 325es and my buddy is piecing together a turbo kit for me. hx35, built head ect. I was concerned because i wasn't sure on what do for a clutch and i also wasn't sure on what size injectors to go with. I have megasquirt, built head, stock bottom end, going to be running 14 psi and obviously im going with a 6 puck clutch but i wasn't sure if their was one out their that's pretty good for the money and wouldn't hesitate too hold about 400 wheel. I also wasn't sure exactly what size and what injectors i should go with... If anyone has any ideas or thoughts or even links would be awesome that would be great, thanks.
    -Chris
    • 37833
    A lot of turbo guys run Spec clutches. For injectors you can go as big as you want on MS. I would get nothing smaller than 40lb.
    Grover Beach, California
    BimmerHeads.com
    • e30kings
      • Oct 2013
      • 35
      For injectors i found bosch 60lb injectors for right around $300 which isn't bad. I have a hx35 and megasquirt and stuff like that so the next thing is finding the correct spec clutch that will hold 400 wheel with no hesitations and converting it to single mass for the fly wheel
      • BMWManiac
        • Dec 2010
        • 1091
        I live in KY, and we have a company called KY Clutch....I'm running their setup, just give them a call and tell them what you want. I got my flywheel resurfaced, new clutch, SACHS pressure plate, new TO bearing for $185.....my Southbend clutch (another KY company) just went out in my M3....I'll be replacing it with a KY Clutch...they ship too
        1997 Artic Silver M3
        CES GT4094r 651hp/615tq @ 24 psi
        • e30kings
          • Oct 2013
          • 35
          oh wow yeah thanks for your help? il be sure to give them a call.. do you happen to have the phone number?
