M20 hard starting
  • amcp
    • 489
    M20 hard starting
    The m20 in my car recently developed a hard starting issue. It does this if the motor is cold or has been running for awhile. It will crank for 30-45 secs then fire. Also, I've noticed that it will stumble while idling. However when it does finally start, it drives fine. Not sure where the problem is. Anyone have any thoughts?
  • Scallywagon
    • 1200
    A good place to start is a stomp test; might reveal some electronics/sensor issues in the system, smoke test can show easily if you have any vacuum leaks.
    ( f ; _ ; )f
    • 603Racing
      • Dec 2010
      • 612
      It's because you took the TRM wheels off the car... it's mad at you. Or maybe I sabotaged it because you pulled on me during that 3rd gear run with your angry 4.10's. :)
      I'll bring you a FPR tomorrow, to test with.
      90 325i DD/Track
      03 Durango 5.9
      Originally posted by e30mpg
      It is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.
