1992 325i Convertible.
I’ve completed the Timing Belt change, along with the other “while you’re in there” items, and now I have a crank but no start situation. I’m hoping it’s something simple I’m overlooking. I’ve done the basic troubleshooting steps of checking for spark, and jumpering the fuel pump relay terminals 30 and 87, so I’m confident there is spark and fuel delivery. The crank position sensor is in its place. Is there another sensor I may have removed or damaged that I can check?
These are parts / work I completed:
Timing belt
Tensioner, spring, pin
Water pump, fan clutch
Distributer cap and rotor
Spark plugs
Alternator and power steering belts
Cam seal and O-ring
Air filter
Cleaned filter box, Air Flow sensor housing, and throttle boot
Thanks in advance,
Rich
Timing belt
Spark plugs
Cam seal and O-ring
Air filter
Thanks in advance,
Rich
