Had the same problem early this year, I just grabbed another head from the junkyard, had it machined, lapped the valve seats and reassembled. Totally worth it.
Someone forgot to do a timing belt change
1991 325i - "Scambles" The Daily Driven lightly modded.
1988 Mazda RX-7 TII "Mako" The Free Dorito
bacon by Jared Laabs, on Flickr -
I just put it all together. Will be firing it off soon.
Sent from my XT890 using Tapatalk
#AZE30
1991 318i
1989 325i
1989 335iComment
make sure you bleed it correctly.
heater on
front wheels 1ft higher than rear
fill coolant let the car get to temp and open/close the bleeder until it stops bubbling. at this time the upper rad hose will get firm and you will get through in the cabin. i usually check my car a week later change the oil and rebleed as a just in case.
use only distilled water and bmw coolant.Comment
