well, I've run into another issue with a wiring problem.
Its an 89 325i wiring harness and complete M20 motor into a 91 318is body.
Motor cranks over just fine, Megasquirt is getting a good signal and is online and running my correct base tune that I use.
The fuse box plugged right into the wiring harness on the M20 as well as the battery box area. There is no c104 connector to be found and i'm getting no fuel.
whats needed to get the fuel pump going?
