M20 Mysterious noise. And bog.
    So I have an m20 that's making a mysterious noise. Sounds like (say chick 10x fast), it happens when I start the car, but it disappears when I accelerate, but when in neutral it comes back again. It's coming from the front end of the car, near the alternator and fan area. Please help me diagnose the problem.
    Also I have a weird bog usually around 2.5-3.5k rpm, on 2 thru 5th gear. Why? It smoothens out around 4-5k rpm.
    have you looked under the hood? maybe at belts.
      How long has it been since you changed the timing belt and water pump? Enough slack can cause the belt to jump a tooth and run like crap. The ticking could be the tensioner or the water pump.
        It's been 4 months since I changed the belts. How much slack is too much?
