Hello all,
Thanks for having me on these forums.
I have had my 1988 BMW e30 320i for around 2 years now and it has never run perfect from the first day I brought it. I wasn't very mechanically minded back then nor am I now and I have been wrestling with thing for a long time.
It hard starts, often have to get pressing on gas pedal to get it to finally start. The idle is rough, gas mileage is pretty poor. It dies/stalls when at a stop light. last time I drove it which was some time ago whenever the gas pedal was pressed it would stutter and want to die. All this seems to get worse once the engine is warm.
I haven't touched the car for a long time and it has been parked up until now. I used to be into swapping parts and generally being pretty newbish when it came to fixing this thing and have since taken a different approach. I have tried fuel pump, ICV, TPS, MAF Sensor, Vaccum leaks (seem pretty tight now) cleaned out intake a bit and icv as it was all oily which brings me to another point that I had to let like 2L of oil out as it was over filled when I got it. It also when to an auto electricians who wasted my time and money and put a few zip ties here and there and whacked a blue temp sensor on. i also replaced the exhaust manifold gasket and the car runs a little worse now if I'm honest but no more fumes are leaking. Recently I have taken all the injectors out and cleaned them and am making some big head way on this thing and I would like it to be fixed once and for all. I took some pictures of the spark plugs and removed the distributor cap and found some hefty corrosion on the contacts.
Any help with this would be greatly appreciated, thanks guys.
