Does anyone change their head gasket as a means of preventative maintenance? Is there a common interval? I'm at 170,000 and thinking about using a spare gasket while I'm at the timing belt.
Head gasket
every 12k miles or 1 yr -> new valve cover gasket, after valve adjustment
only gasket change I found in regular maintenance checks, apart from the part they say to see if others are in good condition. (Haynes service and repair manual)
I'd recommend you do a compression test first.My '88 euro 520i (e34) -> thread -
you will need to have it machined. then new BMW head bolts and Goetze/BMW head gasket. along with valve guide seals and intake, exhaust, thermostat gaskets.
imo the M20 needs a full rebuild at 200k-220k miles. a proper rebuilt m20 stock w/o a chip will own a 220k+lightly moded m20.Comment
