Breather Hose?
  • daspoop
    • 163
    Breather Hose?
    Where does the breather hose (the one coming from the valve cover) connect to?
    Thanks,
  • Chessmaster
    • Jun 2012
    • 501
    It connect to the throttle body.
    • I got it, yes!!
      • Feb 2007
      • 206
      connects to the big vacuum port on the forward side of the throttle body. Not the one going the the idle control valve.
      • daspoop
        • 163
        Any pictures? I have an M20 with no vacuum hoses.
        • BMWManiac
          • Dec 2010
          • 1091
          Look at the throttle body. On the left side, looking from the intake side, you should see a large vacuum nipple....same size diameter as the valve cover, can't miss it
          1997 Artic Silver M3
          CES GT4094r 651hp/615tq @ 24 psi
          • daspoop
            • 163
            I will check tomorrow. Thanks to everyone for the advice.
            • bmwstudent
              • Sep 2011
              • 1364
              Realoem.com will give you detailed pics and part numbers, excellent source for info like your after. You must goto the archive section to find e30's
