Car is mostly fine when coldish, but when I get going, and I accelerate with more than medium pressure on the pedal, the acceleration becomes bumpy and uneven. Any ideas?
Acceleration Problem.
The first thing I'd suspect would the the distributor rotor, cap, ignition wires, and plugs. New OE parts and NGK ZGR5A plugs are called for. Then run the fuel pressure and delivery test in the Bentley manual. If no joy there, have the injectors professionally clean, rebuilt and flow tested (I like RC Engineering) and on a 9/87 or later M20B25 engine check C191 for corrosion.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
