My car is an 87 325is with a whodwho MS unit (still isn't tuned yet but my old ECU took a dump so it's just so it would be at least running) with 19# M30 injectors, and 2.5" straight pipes all the way back. I got a new exhaust trying to chase a bogging that turned out to be clogged injectors and I didn't have new hardware at the time so it has been massively leaking since then.
The leak caused the car to run rich and backfire a lot but ran mostly pretty well. I finally got new exhaust hardware and the leaks are gone and it was fine for a whole night and now it sounds like it is missing a little while cruising and won't rev past 2500 or it'll start bucking and missing severely.
My friend going to school as an auto technician says it's the o2 sensor but unplugging it and resetting the ECU didn't help anything. Tomorrow I am going to see if it'll get past 2500 at WOT since that would bypass readings from the o2 sensor, correct? Any other recommendations? Could the plugs be crapped out or anything else?
Thanks in advance, Peter.
