From low idle to high idle?
  • Tristanf20
    • Sep 2013
    • 4
    Usually i would have a low idle. Somewhere in around the 600 rpm range. Then i changed the intake boot and then my idle is now at 2100 rpm. I checked for vacuum leaks but there are none. I unplugged the icv sensor and the idle didnt change, not sure if its supposed to change or not.
  • dnguyen1963
    • Nov 2011
    • 2649
    How did you check for vacuum leaks? The symptom clearly describes vacuum leaks.
    • dirtbag30
      • Apr 2013
      • 678
      is it staying at 2100 steady? check your throttle cable it might have gotten pulled out of socket and is slightly opened a bit. that has happened to me.
      i have no idea what i am doing with my life
