86 325e issue.. Please Help!
    Picked up another e30, its a 325e. Starts ect, but if you give it any amount of gas it just stalls out.. Fuel pump was just done. Going to be putting in a new fuel filter as well, New AFM, New ICV.. should i go ahead and do all of the vacuum lines? What do we think?
    88' E30 325 24v Turbo Coupe
    91' E30 325i Sedan
    09' E82 135i Coupe (Sold)
    01' E46 325ci Coupe (Sold)
    97' E36 328is Coupe (Sold)
    91' E30 325i m52 Coupe (Sold)
    90' E30 325is Coupe (Sold)
    90' E30 325ic Coupe (Sold)
    88' E30 325is m20 Turbo Coupe (Sold)
    88' E30 325 Coupe (Sold)
    87' E30 325e Coupe (Sold)
    86' E30 325es Coupe (Sold)
    Check the rail fuel pressure.
      Replaced the icv, AFM, FPR and it started and ran rough and died down when i gave it gas again, replaced fuel filter today and now the car just cranks and wont kick over... took the injectors out just about an hour ago and they look a little rough.. was looking at getting replacements and changing those. Just received a new vacuum line kit in the mail as well to replace every hose.. any ideas? Any help would be great thanks!
      91' E30 325i Sedan
        Any ideas?
        91' E30 325i Sedan
          Which fuel pump was just changed? In tank, or the external?
          2011 335i/1995 Mercedes C220 (rallyx)
            Don't rule out a faulty coolant temp sensor. Check its wiring, too...mine had a Reagan-era resistor soldered into the connector, and the joints had broken. It was under the connector boot, well hidden.
              Check the exhaust system. I bought a 325i that had sat for a year. It showed the same symptoms, would start at first but would cutoff when you gave it gas. One of my coworkers saw a few wasps fly out of the tail pipe. The wasp nest was huge and had blocked up the muffler!
                both fuel pumps were changed, i just ordered a coolant temp sensor as well..
                91' E30 325i Sedan
                  This problem sounds familiar. You may have fuel, are air and spark good too?
