Removing Crank Bolt with tires on ground and car in 5th???
  • Overlord475
    • Dec 2010
    • 799
    Would like to replace my front crank seals while doing my upcoming HG and was wondering if anyone has had success at removing the crank bolt with nothing more than a breaker bar, extension pipe, the car in 5th, rear tires on the ground, e-brake on, and maybe someone siting in the driver seat pressing on the break pedal?
    I don't want to spend the $60 for the special crank holidng tool:
    http://www.pelicanparts.com/catalog/...TD182_pg76.htm
    Peerless had a great write up here:
    I do like Peerless's method though, ha:
    --->>>1988 SETA 2.7i Build Thread (Turbo Prep)<<<---
  • Click
    • 637
    I accidentally loosened mine once by leaving a wrench on it and starting the engine...
    ส็็็็็็็็็็็็็็็็็็็็็็็็็
    I need you to exfoliate my ballsack
    Build Thread?
    • Cabriolet
      • 9620
      starter will break it loose.
      http://www.flickr.com/photos/59570093@N08/
      we use a bed frame
      Much wow
      I hate 4 doors
