What thermostat to buy
  • aaron_tupper
    • Oct 2013
    • 134
    Should I go with the 80'C one or what one should I go with?
  • dirtbag30
    • Apr 2013
    • 678
    what motor? does your car run a little on the hot side now? oem is 88c i believe, but i run a 80c thermostat in my 24v with a 318i rad.
    i have no idea what i am doing with my life
    • blunttech
      • 12850
      Get the one designed for your motor. If its overheating you have other issues. A lower thermostat isnt going to make your car run cooler
      sales@blunttech.com
      www.blunttech.com
      Like us on Facebook
      • aaron_tupper
        • Oct 2013
        • 134
        no
        Its bad. My car just says it runs really low in temperature Like in the blue
        • aaron_tupper
          • Oct 2013
          • 134
          no
          • aaron_tupper
            • Oct 2013
            • 134
            m20
            Its a m20 btw
            • blunttech
              • 12850
              Get yourself an infrared thermostat They are cheap and you should have one. Point it at the upper rad inlet (not the hose) and measure actual temp when fully warm. Gauges arent always accurate due to grounds etc etc
              sales@blunttech.com
              www.blunttech.com
              Like us on Facebook
              • ak-
                • 12422
                Whatever stock is, 88? If it runs in the blue then there is a possibility your thermostat is stuck open, so bravo for replacing it regardless.
                1991 325iS turbo
                  • 37832
                  I always... ALWAYS... run stock temp thermostat.
                  As Blunt said if your car is heating up you have other issues.
                  My turbo M20 doesn't heat up one bit on a 100 degree SoCal day.
                  Classic BMW Specialists
                  Grover Beach, CA
                  www.BimmerHeads.com
                    An 80C thermostat would be the stock part for an M20 and is the best choice.
                    • aaron_tupper
                      • Oct 2013
                      • 134
                      Thank you
                      Thanks man thats what I bought lol
