Did the head swap a while back, and I've got some problems I haven't quite been able to work through yet.
-Getting about 10 mpg, white smoke out the exhaust at stop lights, loss of power up to around 4k rpm, bogs a little bit with a quick throttle input
-Had a really funny idle (idled at 2000 rpm), turned out to be TPS. Adjusted, the car now has a little bit of idle fluctuation between 7-900 rpm
-No redline! (will rev past 7k)
Used an unopened 173 ECU
I've tried finding vacuum leaks around the intake boots, throttle body housing, ICV, brake booster, etc.
The idle bypass on the AFM has been adjusted in the past.
The Pulse Sensor (on one of the spark plug wires) was pulled at the junkyard, not sure how to test if it's working or not.
TPS won't give me a stomp test (nothing happens)
Already changed out spark plugs, didn't help.
The Bentley isn't helping much, and trust me, I've tried the search function.
Anyone got any ideas?
