Head Bolt Swaping??
  • 1990e30coupe
    • Jul 2010
    • 126
    Head Bolt Swaping??
    I have a 1990 525i that I bought a new set of head bolts for a while back that are Torx and was wanting to know if I can use them on my 1987 325e which has Hex bolts right now! Also what ever bolts I use are they all 22lbs and 90 90? the book says it matters how you torque them depending on using Hex or Torx
    What BMW means to me: Breaks My Wallet
  • Regnar75
    • Sep 2011
    • 483
    I forgot when it was but BMW officially made the move to Torx over hex and I don't think you can even buy Hex head bolts for the m20 anymore.
    here's why...
    http://www.pelicanparts.com/bmw/tech...d_bolt_fix.htm
    Also i believe it is still 22lbs 90 degree 90 degree
    • 1990e30coupe
      • Jul 2010
      • 126
      here's why...
      Awesome! Thanks for posting I figured I could use them since the e and I heads are still on an M20, but I just wanted to make sure from a beginner stand point.
      • AndrewBird
        The Mad Scientist
        • 11897
        As long as the bolts are new and never used, they will work fine.
        • 1990e30coupe
          • Jul 2010
          • 126
          Heads back on all torqued thanks for all the info!
          • efficient
            • Feb 2012
            • 3312
            hmmm i was wondering this the other day but instead of stock i would like to use arp studs
