Im using an m52b28 crank in my m20 block with stock b27 rods. so im just wondering should i just buy standard size bearings or get .25mm oversize? or how could i measure it to know before hand? first time building an engine so kinda paranoid to get it right.
how to know which main bearing and rod bearings to buy?
If you're paranoid on getting it right and a first timer I'm sure you're getting the crank and rods checked out by a machine shop. They'll tell you if the crank needs to be ground undersized and if your rods need to be rebushed.Comment
You measure the rod and main journals on the crank. You'll need a micrometer that reads to .0000 or better. Make sure you make at least a couple measurements on each journal to make sure they are round. You still might want to take it to someone to have the journals polished.sigpicComment
