Help me diagnose an intermittent bucking/CEL problem
  • kwseattle
    • Nov 2013
    • 105
    Sorry about the incoming wall of text:
    So when I first bought my car in December it would occasionally buck/misfire when on the throttle getting on the freeway or going up a hill, etc. Now it's progressed to about every day when I drive it there's at least one stutter, one bucking event, etc., and it's also been stalling at idle. It also has the occasional long start, taking about 5-6 seconds to fire while stumbling to life.
    Last weekend I was about to head north to school (about 80 miles) and when I pulled out of my parents driveway it immediately started bucking every time I hit about 2000 RPM. I had to turn around at the end of the block and pull right back in their driveway. Here is a video while in neutral, foot steady on the throttle: https://www.youtube.com/watch?v=YVg0sM1wjQg. You can't see in the video, but every time it happened the CEL would blink on and then shut off. After shutting it down the check engine light came on and the stomp test proved itself useless by just flashing constantly and not displaying any codes. I checked the spark plug wires and pulled them off/put them on several times to make sure there was connection, and then the problem repeated itself only at 4000 RPM instead.
    The next morning my dad and I checked the throttle position sensor and the crankshaft position sensor, both seemed to be within spec as per the TPS Pelican Technical Article and the Bentley manual. I ended up replacing the fuel pump relay just to see if that would have any effect. Car started and drove normal, no problems all the way back to my house 80 miles north.
    Last week it has been bucking/stuttering at idle quite often, about once per day. Long starts are still happening. It will often stumble when idling and the check engine light will come on for a few seconds, then go out. It falls suddenly to about 400 RPM then jumps to like 1300, then falls back to a normalish idle.
    Yesterday I replaced the throttle position sensor only to find the one I'd gotten was faulty, so I put my old one back on (seemed to be working fine) and discovered that my friend and I had created a vacuum leak in the process. We also unplugged/replugged every sensor multiple times to make sure that electrical contact was being established and there wasn't any corrosion on the terminals. It started and drove home fine though, but it hated quick throttle input and idled high due to the vacuum leak.
    I need some input. Could it be the AFM? ECU? The ECU has a chip but I have no clue what kind. I have access to both a working spare ECU and even a MAF conversion if I so chose to try that.
    I'm running out of ideas. Oh and I forgot to mention that it also runs rich. Has been since I bought it.
    Alpinweiss II 88 325is | M20 | 5 Lug Conversion
    Kyle
  • FLG
    • Sep 2011
    • 3165
    Looks like your typical CPS issue, DME looses timing data, tach cuts, then catches.
    Unplug the CPS sensor (wire near intake by round connector) there are identical plugs so make sure you remove the correct one, the other is the spark inpluse sensor. Check the resistance on the middle and outside pin (think pin 1-2, but middle and one of the outside ones will read infinite the other will read resistance) the resistance should be somewhere around 540 ohms + or - 10% or so.
    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
    • kwseattle
      • Nov 2013
      • 105
      I've actually tested it, it was really close to 540 ohms between the outside and middle pins.
      I can still replace it if necessary, they aren't terribly expensive.
      I think I've read somewhere that if the MPG gauge moves when it happens it could be fuel related, could this be the case?
      OH and it runs rich. Maybe the AFM isn't working correctly, too much fuel? Would the AFM also cause stutters and idle issues? MY ICV is also functioning properly, I believe.
      Kyle
      • FLG
        • Sep 2011
        • 3165
        The tach drop out and mpg moving is DME/CPS/Wiring related.
        Just because it reads properly dosnt mean its working right, but its a good sign it ohmed correctly.
        Could also be DME losing power, last time i had this issue i hooked up LED's to pins 18 Un-switched Power input, 37 Power Input from Main Relay on the DME to see it they would turn off when it happened, they didnt. Turned out to be some corrosion on my c101 connector near the fuse box.
        Clean the connector off, remove the rubber boots and look for any shorted wires then go from there.
          I agree with the cause being a loss of timing data to the DME. Just because a CPS ohms out, that doesn't mean that it works properly. Replace the CPS with a new OE part to start. If that doesn't help, replace the DME. If neither of those help, replace the engine wiring harness.
          • kwseattle
            • Nov 2013
            • 105
            Thanks for the tips. Yeah I'll try another DME and check the wiring, and another CPS once I can get my hands on one.
            Kyle
            • FLG
              • Sep 2011
              • 3165
              Just make sure its an OEM cps, not aftermarket junk.
              • kwseattle
                • Nov 2013
                • 105
                Yep, only the best.
                Kyle
                • hasback
                  • Aug 2013
                  • 111
                  is there any easy way to replace that without pulling all the hoses, belts,radiator ect, that what the Bentley seems to want you to do. i have the same problem as well.
                  • FLG
                    • Sep 2011
                    • 3165
                    Replacing the cps sensor is as simple as unplugging it and removing the bolt holding it onto the front of the engine. Allen head, not sure what size. Make sure you route the new one properly, if care is not taken it can easily be chewed up by the fan pulley.
                    Sent from my SCH-I545 using Tapatalk 2
                    • E30-325iS
                      • Sep 2011
                      • 191
                      When ordering the CPS get new clips to hold the cable as it runs past the front of the engine, as they wil probably crack when you remove them.
                      Number 14 and 15 in this diagram.
                      http://www.realoem.com/bmw/showparts...11&fg=10&hl=84
                      • FLG
                        • Sep 2011
                        • 3165
                        Honestly I avoid mounting it that way. I go up and over the thermostat instead.
                        • dnguyen1963
                          • Nov 2011
                          • 2649
                          Did you take care of the vacuum leaks? Your car will drive like a wild mustang if you have large intermittent leaks.
                          • hasback
                            • Aug 2013
                            • 111
                            okay see in knew id have to take all the hoses, fan and what ever else to re route. so to me it sounds like the easier way is to cut/pull the old sensor out and then re run the new one over top of the motor?
                              The alternator belt, fan, and water pump pulley are all that have to come off to route the CPS the way it should be. Do, as E30-325IS suggested, have a new chase and clips on hand.
