Failed Ca Smog - Help!
  • mmire30
    • Dec 2009
    • 50
    Hey everyone,
    So i failed smog today and am trying to figure out why. I have attached the failing numbers below. The failing values have been highlighted. Can anyone shed some light on what the possible issues are?
  • CarsSuck
    • Oct 2005
    • 968
    Hi NO means the engine is running lean. High HE means your bring oil. I would investigate air leaks with special attention to the vent hoses and breather tube orings. And run 15w 50 oil.
    --Will
    • mmire30
      • Dec 2009
      • 50
      what is the breather tube oring?
        With those numbers the first thing I'd suspect would be intake leaks. A smoke test will find them.
