oil leak from distributor??? need part number help
  • Mr. Burns
    • Aug 2011
    • 3516
    I get a couple drops of oil overnight from my M20b25.
    I think I've sourced the leak to the distributor, and from what I know there should be a rubber seal\ring in which prevents this leak.
    I wanted to look up the PN, but real oem is showing there is none?
    Originally posted by flyboyx
    i have watched my dog lick himself off a few times
  • LJ851
    • 7919
    The dist cap is not supposed to have oil in it. Oil leaks from the front of the head are the camshaft oil seal and the oring around the carrier for the cam oil seal.
    Lorin
    The M30 is God's engine.
    • Mr. Burns
      • Aug 2011
      • 3516
      a sh*t.
      this will be a much bigger job than I had anticipated
      thx
      • mpowerful
        • Jul 2013
        • 1273
        yeah basically gotta take the timing belt down to do it since the camshaft pulley has to be taken off.
        Im bored so.... Anyway ..... http://www.pelicanparts.com/catalog/..._pg1.htm#item0
        • Mr. Burns
          • Aug 2011
          • 3516
          It's only a couple drops nightly. I think I'll turn a blind eye to it till swap time
          • LJ851
            • 7919
            How old are the 4 rubber plugs that seal the rocker shaft notches under the valve cover? Maybe you are lucky and its them leaking.
            Lorin
            • Mr. Burns
              • Aug 2011
              • 3516
              couldn't tell ya...
              I'll have another look and try to pinpoint it a little more
              • Mr. Burns
                • Aug 2011
                • 3516
                thx!
                • mpowerful
                  • Jul 2013
                  • 1273
                  Mine seeps a little too because i was in a hurry to do the belt when i got my car and didnt change the seals. Number 14 in the first diagram should keep the oil out of the actual cap. As far as amount....mine is so slow there is no perceptible (ok maybe 1-2mm) oil loss on dipstick at 5k mile oil change intervals.
