Ive got it all you guys. I searched and no luck.
Ive done alot so far, my car is an early 86 eta manual.
The car was parked in 05 due to a problem...which I suspect is what Im on now.
The car starts like perfect, and will idle right on 750rpm... sometimes, other times it idles as high as 1700rpm and you can bottom out the icv and it still idles as high. The oddest thing is that you can let it drag itself at about 800rpm and it will stay there after a minute or so. But, as soon as you touch the gas pedal the rpm will climb again. Ive had issues with the car missing, like its only running on two or three. Ive had it to where you could start the car, and it runs fine for 10 seconds til it starts stumbling, shut it off and start again and it runs fine for another 10 seconds.
Also, worth noting is the fact that the car smells very lean though I havent checked plugs to confirm.
Ive had the injectors cleaned at MrInjector.
Replaced fuel with clean, new.
New fuel filter twice.
Different ICV and control module
Different ECU
different TPS
Different wiring harness
Different AFM
Different Fuel Injection relay
Different Main relay
SMOKE TESTED FOR VACUUM LEAKS (none)
CHECKED FUEL PRESSURE (35 or so at idle, jumps up around 40 when youre on it)
Verified spark at each cylinder.
New spark plugs and wires
New air filter
New Cap and rotor
Honestly the only thing I think I havent swapped out is the coil...
I really am simply at a loss, is there a part I havent thought to check?
-Webb
Different ECU
different TPS
Different AFM
New air filter
New Cap and rotor
-Webb
