Hey Rev,
I am not getting any spark, figure its the crank sensor. It is on a 1987 325e!
I pulled the motor and put on all new seals/gaskets. What I need to know is if there is supposed to be an air gap for the crank sensor and what the amount is as far as numbers for measure.
Also the sensor is wired to what I believe is a test site/plug and then routs from that to the brain, but I have never seen two test sites (just obd1), therefore, can someone clarify for me if its an actual test site.
If it is a bad sensor I wouldn't even know where to begin to change it out since its hard wired in.
Any help would be greatly appreciated!
Thanks Rev
Thanks Rev
