Just need some help troubleshooting a problem. My m20 tends to run bad when its been sitting in the rain or if it rained overnight. It will will idle relatively normal but bog down/load up until I get the motor heated all the way up and try and run it up through the RPM's. I don't know why it does this can y'all help?
m20 runs bad in the rain?
You could try misting the above-mentioned parts with a squirt bottle, one at a time, to see when it bogs down to see which part is the culprit.Comment
My friend had the same problem, it ran great when it was dry. In the rain not so much. Finally the problem was the engine ground wire. In the rain the engine ground got wet and and didnt give a good signal anymore. A new engine ground doesn't cost much anyway and it's easy to replace.Comment
