Spark plug wire fitment question
  • NeedaE30
    • 397
    Been looking for decent priced plug wires w/inductive pick up wire, I found a set of bosch 09507 plug wires that apparantly fit an 88 635csi they look identical to the e30 325is m20 wires. and they are about 50 bucks cheaper from what i've found.. will they work?
    No idea, but the smart move is to get the OE/OEM wires. You know they will work and since they'll last another ten years that would be money well spent.
      • 37828
      They should "work" but you would need to remove them from the plastic housing and re-use the one from your M20 wires.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • george graves
        • 19993
        They will work, but they will be about 2" longer. If you can find them cheap - go for it.
        Originally posted by Matt-B
        • NeedaE30
          • 397
          Yes i found them for around 85 bucks compared to the 130+ for the 325is wires and they include the inductive pick up wire, so i think ill be picking them up thanks guys
          what do you guys think?
          http://www.amazon.com/Bosch-09507-Pr.../dp/B000BZEFZK
          • 4evere30
            • Nov 2012
            • 57
            They will fit and work fine but you won't be able to fit the plastic slash guard cover over were they plug into the distributor anymore....that's how it worked out with the 535i wires I've been using on my 325i anyway....no problems with em after 3 years of use...
