Hello,
I really tried searching the webs and here and I hate posting. I'd rather figure it out my self. but im stumped..
Basics: 2.7i from seta. green top 17.5 inj, full swap. ECU 173, cam, valve springs, oil passages, intake, TB and AFM.
Never really idled super smooth after sway but good enough. PROBLEM- car will start instantly, goes to 1k as norm, comes down to normal idle and just keeps dropping,chugs and barely catches, surges. DIes, instant resart, same idle.
Last week: Thurs when cold, first thing in AM, starts and runs fine. Get to partial warm up, shut off. Restart, instant start up but idles like crap. then clears up 2mn later and runs as usuall. Gets full warm, shut off. Restarts instant but crap idle. clears up.
SATURDAY, starts and idles like nothing was wrong. gets warm and idles a bit rough as norm. Drive for 20mn- full warm. Turn it off, it sits 15 min and instantly starts but idles for crap. Throttle doesnt really help, choughs and sputters though till something clears up and then runs fine.
think its maybe Leaking injectors??? so I swap back to the seta injectors. Disconnect batt. reset ecu. Starts right up and idles/runs great. Take it out and romp on it some. SHut it off. restart 10mn later, runs fine.. great, its fixed...
SUNDAY starts and run fine in am..... drive 25 min, shut off. Restart, idles and runs fine. drive another 35mn park for 3.5 hrs, starts right off but stumbles some. smooths out. Drive 10mn, resart, idles like crap, then clears up. Drive 20mn, eat chipotle, instant start, crappy idle, clears up fast. on to Gander and Walmart. Starts instantly each time but idles poorly longer. Drive the 40mn home restart instantly after shut down and runs fine. Wait 45, instant start, poor idle, but it clears. Go for another errand shut down, wait 10mn resart runs super super crappy, cant even drive it. Get a 1222 code- thanks for nothing motronic:(
Disconnected batter to reset ecu- doesn't help
Disconnect O2, runs even worse. O2 is ok.
Swap ICV- no difference
Swap Fuel Reg- no difference
Swap AFM- nothing.
work in garden 2.5hrs
DO smoke test, fix one SMALL leak.
starts instantly idles poor but better, clears up. Take out and flog. Normal power through entire RPM. Turn off wait 5, restart and everything is good.
THIS MORNING- am-instant start and runs like BUTT!!! Disconnect CTS and instant idle change, smooths out, drivable. Let get to temp, idles better than ever, shut it down. Restart 2hr later, instant start, crappy idle. same things through out morning.
AT LUNCH-
PUll off vac line to FPR and squirt starting fluid in as its chuggin and surging. IT HELPS
Suspect fuel pressure- its ok
Notice if I floor it will rev perfectly but wont idle. Revs all the way to 5-6k. comes to idle and crapps out.
suspect TPS- swap and adjust a good one- NO DIFFERENCE
swap CTS- nothing
Swap FP and 02 relays- nothing.
Possibilites I can think of:
Head gasket- BUTt would still run like crap after sitting over night vs 2hr. and it revs fast when you get on it hard even at rough idle. Not to mention it instantly starts, goes to 1k then comes down like it always has. Coolant would be a long crank and sputter to life I would think.
CPS- BUT it starts instantly ever time.. plus if it decides to clear up and run, everything works as it should.
DIGGER and Jvlie and FF HELP!!!!!!
Swap AFM- nothing.
AT LUNCH-
swap CTS- nothing
