Okay so when the car is at Idle and you flick the accelerator the motor drops in RPM before it goes up. I was thinking it was the TPS, but I checked the Ohms and it seems to be fine. I have been searching for a vacuum leak but I haven't had any luck! I checked the intake L boot, the ICV, and other vacuum lines. Also when you pull through second gear, throttle fully open, from about 4000-5500 RPM the motor seems to lag and pick back up again just slightly.
Here's a video:
Here's a video:
